Error Code Messages that WON'T ever show up?
given all the work my car has had, the only error code messages that ever showed up concerned light bulbs.... so what in the $#%& is the added value of having that message screen??? What other type of messages/warnings should I expect NOT to ever appear on that screen?
- Has thanked: 17 times
- Been thanked: 35 times
Ummm, not to be rude but the message center does tell you an awful lot (sometimes too much in my opinion). I guess it won't tell you if the inside of the cabin smells because one of the passengers farted. I don't know...again, I'm not trying to be rude, but some stuff you have to just figure out or check yourself- like a visual of the tires before you hop in to go for a drive to see if they might be low...the message center certainly won't tell you this.
you're not being rude, and I'm simply speaking from my personal experience... maybe i should make sure my msg center is working properly? uuuggghh.MadeInJapan wrote:Ummm, not to be rude but the message center does tell you an awful lot (sometimes too much in my opinion).
now, THAT would be priceless!!!MadeInJapan wrote:I guess it won't tell you if the inside of the cabin smells because one of the passengers farted..
