Tail light always off please help
john83
Year and Model: 1998 S70
Post by john83 »
Hello,
Sorry for my english approximate....
I have a volvo S70 and when a i have the light from ok, the turn signal ok all is ok but not the Tail light.
I have changing fuse but it is the same
i have changing the ampule but the same problem
Please help
I can not have the tail light on my car, can you help me please
Maybe one relay i don't know were is the relays
I hope you understand me and help me
Best regards
John from France
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
A couple of my cars have occasional problems with bulb holders for rear lights. The bulb may be loose or the bulb holder may not make good electric contact with the wiring socket. I do not have a real solution, but twisting the bulb and bulb holder usually makes them work again.
Sometime the bulb just burns out and needs to be replaced.
crlande
Year and Model: 240DL;850;S70
Has thanked: 1 time
Been thanked: 36 times
Post by crlande »
Our cars have a "bulb out light" on dashboard, this may help to diagnose.
john83
Post by john83 »
I have no bulb out ligh on dashboard. some one said me may be one relays .....
Help All other light work the stop light ok the rear light ok the turn signals ok and in the front all work
john83
Post by john83 »
i have discovert this morning the problem com from them
lighting control i open it and cleaning it now all work fine !
Has thanked: 2199 times
Been thanked: 1852 times
Just for reference, some of the bulb light out only work when the item is used like brake lights.
The headlight switch is a known weak point on these cars and was subject to a recall. The dashboard lights are switched on with the light switch, but are controlled for brightness by the slider to the right of the light switch. I have the light dimmer slider fail on me or only work in certain points.
