Volvo S70 2000 Check Engine - SYSTEM TOO RICH
JBurb66
Year and Model: S70 2000
Post by JBurb66 »
Hi. I am the owner of a 2000 Volvo S70 SE, 2.4L no turbo. 208k km.
This morning, when I first started it, I noticed that the check engine light was on, which wasn’t the case last night.
Curious about it, I plug my obd2 scanner and the code P0172 comes up, with the indication « system too rich » below. After checking it up, it means that the air/fuel mixture in the engine contains too much gas.
The symptoms of this code listed on the website do match what I noticed on the car afterwards, which include:
- higher fuel consumption (13.6 L/100km on the information screen, instead of the habitual approximate 12.8)
- An anormal quantity of smoke coming out the exhaust (white/grey smoke thought, not black)
Since I bought it, there was always a smell of gas (outside, not inside) when I start it, I believe that there is a leak somewhere in the exhaust system. Maybe this is related to what happened this morning.
I also know that there hasn’t been any engine oil change done in (at least) the last 1.5 year. The lady I bought it from lived in the downtown of a big city and barely drove it. Also, my friend (who knows more about volvos and work as a mechanic) and I frequently checked the engine oil in the last few weeks and it always seemed perfectly fine. Because of that, I still didn’t change it.
What do you guys think I should try first? I’m thinking about checking the spark plugs first, since I read that the gas smell could be one of the many causes of this (if its not an exhaust leak) and also one of the many causes of this morning’s problem.
kallekula
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
Clogged air filter, leaky injectors, wrong injectors, wrong fuel pressure etc etc. New plugs are always good. Buy plugs from Volvo. Some cars are very picky about it being exactly the correct type.
Your catalytic converter is taking a beating by the rich mixture so if you care about emissions it’s high time to dig in and solve this.
EDIT: older oil can contain “a lot” of gas. Good idea. I think I would start by changing oil and take it from there.
BMW 540i 2002
S70 Base 2000
misha
Year and Model: '97 850 2.5 20v
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
P0172 is in '99.9% a vacuum leak somewhere.
Could be in exhaust before front o2 sensor,between the front & rear o2 or in intake after the Maf sensor.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
kallekula
Post by kallekula »
Check upstream O2 sensor
Check maf
BMW 540i 2002
S70 Base 2000
kallekula
Post by kallekula »
If u have a vacuum leak u have a lean condition. Wasn’t the problem the unusual opposite?
BMW 540i 2002
S70 Base 2000
Has thanked: 1503 times
Been thanked: 3817 times
It’s isn’t telling you it’s too rich, it’s telling you the long term fuel trim has reached the lower limit of range. Subtle distinction
It’s 99% caused by air or exhaust leakage. The system is trying to compensate for AFR based on feedback from the OXS, and leaks can mess it up either way
kallekula
Post by kallekula »
So its a lean condition
BMW 540i 2002
S70 Base 2000
JBurb66
Post by JBurb66 »
Thanks for all your replies, I'll check that up when I have time.
