NA head on 2.3 Turbo? Topic is solved
Clemens
Has thanked: 473 times
Been thanked: 219 times
Post by Clemens »
I'm in the process of parting out a 93 NA (20 V). Will the head fit on my 94 T5M or 96 R? Imy guess is that the bare block and the bore is identical, but the stroke is different.
If the head is different, then at least the cams and Valves are worth saving because the NA cams are a nice upgrade and I believe the valves are identical.
Any word of wisdom is appreciated.
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 112 times
Post by Goupil »
I believe the turbo valves are different in the material they are using (sodium filled or something like that?), but the head in itself might be the same thing.
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
Chuck W
Year and Model: 97 854 T5
Has thanked: 96 times
Been thanked: 337 times
Post by Chuck W »
Cams are worth keeping.
Clemens
Post by Clemens »
That was my initial thought as well.
But then I thought about the whole head, but since the bore of the NAs is different and the valves may not be sodium filled on NAs, the cams might be the only thing worth saving
Summer: 1996 855 R
Donor: 1995 854 10V
Has thanked: 293 times
Been thanked: 765 times
Post by erikv11 »
Valves are Na filled on the turbo head, not Na filled on the NA.
Na fill is N/A on the NA.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
Has thanked: 1506 times
Been thanked: 3820 times
erikv11 wrote: 05 Oct 2022, 23:29 Valves are Na filled on the turbo head, not Na filled on the NA.
Whoa whoa whoa, goodbye……
Clemens
Post by Clemens »
To sum it up, nothing except for the cams and the intake out of a NA can be reused in a Turbo car, if I understand correctly.
Summer: 1996 855 R
Donor: 1995 854 10V
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
Or everything except the exhaust valves ?
1999 V70 GLT
Post by erikv11 »
Clemens wrote: 05 Oct 2022, 22:23 ... cams might be the only thing worth saving
Also on this point, FWIW, the 93 NA cams are preferred over other, later years. They have slightly higher lobes. But maybe thhat's the 93 year for North American cars, not European?
'06 S60 R, 197k
Clemens
Post by Clemens »
And do the 93 NA cams work better when installed by a virgin in a full moon's night?
Summer: 1996 855 R
Donor: 1995 854 10V
