Instrument cluster lights not working
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
dksoutha
Year and Model: 2006 XC70
Has thanked: 7 times
Post by dksoutha »
I replaced my original instrument cluster with a used one from eBay. Besides adding 115,000+ miles to the car, some of the lights do not work - specifically the numbers on the speedometer and tachometer do not illuminate, though others lights work fine. Any ideas? Also, is there a way to use VIDA to correct the indicated milage?
MDK
Year and Model: 2004 S60R
Been thanked: 41 times
Post by MDK »
MDK here, I'm sure that what you're saying is true however the forum needs to know what kind of Volvo it is and the year. I had a 2002 v70 and the entire cluster would work when it wanted and turned out it needed the circuit board on the back resoldered.. you can't change the mileage, it's hard wired in. You should get the old one back and start again.. in my opinion
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 114 times
Been thanked: 263 times
Post by Blacklab467 »
You can buy the lights and replace them, theres two different kinds on the instrument cluster with a total of about 15 or 20 lights. I always grab a bunch at the auto wreckers as my car seems to burn them out frequently also.
2003 XC 70 (sold)
