My replacement for Part #30620958 for V40 1.9T
This topic is in the MVS Volvo Repair Database » Vacuum Brake Booster Switch Fix -- Part #30620958 for V40 1.9T
shatayl7
Year and Model: 2004 V40
Post by shatayl7 »
After struggling after trying to find a replacement for the vacuum brake booster switch I decided to try a part that was easily accessible. This is a write up of what I did and the parts I utilized to replace part #30620958.
Parts List from Amazon
B003GBIJ5I (90 degree check valve going into Brake booster 1/2" booster end to 3/8" barbed end)
B003VAVMKI (90 degree Elbow Plastic for no corrosion issues)
B08FS47MQD (Replacement switch all barbs are 3/8")
B07NDVD19P (Heavy wall Silicone hose kit variety of sizes I had to replace some other rotten vacuum lines on the intake that's why I chose this kit as well as the different sizes for fitment there was plenty of hose for the job and the other lines I needed to replace Mostly used the 8mm was a tighter fit)
B07GDCH1YK (oetiker clamp kit was just my preference instead of worm drive clamps)
I chose the extra check valve at the booster instead of a 1/2" to 3/8" barb so i would have more options in rotating the parts to find a good spot for the new switch to sit. I also was not sure the valve would fit in the original position given that the barbs are straight and not angled like the OEM Switch. I Also reused the fitting connecting to the vacuum pump. After assembly the vacuum pump started to suck and shut off as it is supposed to after a certain vacuum was obtained. Brakes were back to full function at start up. Everything worked well on a test drive and it didn't seem that the hoses were routed in a manner that they would be subject to excessive heat. I hope this helps those who are in need of the part that volvo no longer makes.
90 Degree check valve fitting in brake booster
90 Degree fitting
90 Degree fitting
Assembly for switch to plug into the booster
fit up
fit up
Reused fitting for attachment to intake
Switch placement
Switch placement
Switch placement
Switch placement
re route of hose going to intake manifold
Fit up
Fit up
Fit up
Fit up
Fit up
Fit up
Fit up
Fit up
Vacuum pump connection
Final placement with covers reinstalled
MOV_1847.mp4
(36.47 MiB) Downloaded 574 times
Final hose routing
eroman2000
Year and Model: 2002 S40
Post by eroman2000 »
I just found your post and am going to give it a try myself. I have a 2002 S40 with a definite leak on this brake booster hose where it connects to the intake/throttle body, but figure it will all probably fall apart or break once I start trying to fix that. Thank you for this write up, and will let you know how it goes.
davidchecker
Year and Model: 2003 S40
Post by davidchecker »
Absolutely terrific, thanks!
Stilltrying2
Year and Model: 2001 S40
Post by Stilltrying2 »
re: Similar issue
Greetings,
After 24 years this hose failed at the Brake Booster end - just crumbling due to age. Please see attached.
I have checked all my sources (more than a dozen) and can't find the part anywhere = Part # 30616993,
I bought a bunch of exact or similar parts that fixed the problems.
If interested – send me a note and I’ll send you the parts list + sources.
Rregards,
Tom
Brake Booster Hose 30616993.JPG (11.88 KiB) Viewed 4375 times
