shatayl7 » After struggling after trying to find a replacement for the vacuum brake booster switch I decided to try a part that was easily accessible. This is a write up of what I did and the parts I utilized to replace part #30620958.
Parts List from Amazon
- B003GBIJ5I (90 degree check valve going into Brake booster 1/2″ booster end to 3/8″ barbed end)
- B003VAVMKI (90 degree Elbow Plastic for no corrosion issues)
- B08FS47MQD (Replacement switch all barbs are 3/8″)
- B07NDVD19P (Heavy wall Silicone hose kit variety of sizes I had to replace some other rotten vacuum lines on the intake that’s why I chose this kit as well as the different sizes for fitment there was plenty of hose for the job and the other lines I needed to replace Mostly used the 8mm was a tighter fit)
- B07GDCH1YK (oetiker clamp kit was just my preference instead of worm drive clamps)
I chose the extra check valve at the booster instead of a 1/2″ to 3/8″ barb so i would have more options in rotating the parts to find a good spot for the new switch to sit. I also was not sure the valve would fit in the original position given that the barbs are straight and not angled like the OEM Switch. I Also reused the fitting connecting to the vacuum pump.
After assembly the vacuum pump started to suck and shut off as it is supposed to after a certain vacuum was obtained. Brakes were back to full function at start up. Everything worked well on a test drive and it didn’t seem that the hoses were routed in a manner that they would be subject to excessive heat. I hope this helps those who are in need of the part that volvo no longer makes.
90 Degree check valve fitting in brake booster
90 Degree fitting
Assembly for switch to plug into the booster
fit up
Reused fitting for attachment to intake
Switch placement
Switch placement
re route of hose going to intake manifold
Fit up
Fit up
Fit up
Fit up
Vacuum pump connection
Final placement with covers reinstalled
3 Comments
Hi, I’m having the same problem. I noticed that some of the parts you recommended on Amazon are no longer available. Could you help me find suitable replacements or suggest alternatives? I’d really appreciate your help. Thanks!
Good
This really helped. I did exactly as you suggested and my 2004 V40 is doing great. Many Thanks.
