850 1996
850 1996
Good day to all, Perhaps someone knows the logic of the EVAP valve. I changed the intake manifold from variable to constant volume. It lacks lines for vacuum control of the EVAP canister. I replaced the canister with a passive one and installed an electric valve on the purge line. But since I have LH 3.2, it does not have access to control the EVAP valve. I want to connect it to the main fuel system relay to open when the engine is running. Will it be right?
