I have 1998 that I am trying to pull some CCM codes on. I have downloaded the demo version of Vol-Fcr 1.3. I have the VAG Kkl usb cable set to com1 on the laptop. I can’t get the software to work or connect to car. I have lowered the baud rate but no luck. When I try to initiate coms I get an error. I can take a picture of it the next time I hook up. The software loads up fine at at least it appears to.
Could it be the demo version? I hate to buy it if the demo version is. It working.
I am not running the ftdi version.
1998 S70 Vol-Fcr win 10
Tbourvolvo
- Year and Model: 1998
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Vol-fcr works only with win XP.
You need an old laptop with serial(db9)to obdII cable...or to install xp emulator on win10 since you have usb to obdII cable.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Tbourvolvo
I’ll try to load the XP emulator. Thanks.
yanga001
- Has thanked: 62 times
- Been thanked: 115 times
I got it to work with virtual box and xp prior while on mac os el capitan, hope it helps
2008 S60 2.5T Auto (Sold)
850oldschool
- Year and Model: 1996 850 NA
- Been thanked: 45 times
Did you need to install the "guest additions"? Also which cable did you use?yanga001 wrote: 23 Dec 2022, 10:48 I got it to work with virtual box and xp prior while on mac os el capitan, hope it helps
yanga001
Yea i believe in installed one, i had a blue vag com kkl cable with the FT232 chip inside (BLUE CABLE), was a china order special. The ELM327 one does not work for VOLFCR.
Tbourvolvo
Well I got the virtual box XP running within windows 10 with the demo vol fcr program. The VAG cable will not install in the virtual machine. It shows up as a yellow ? In the device manager. Any attempts to manually load the drivers are not working.
I will check to see if guest additions is loaded.
Tbourvolvo
I have the kkl vag-com. Blue cable for 409.1
Tbourvolvo
Yep guest additions is loaded.
- 39 Replies
- 30802 Views
Last post by bmdubya1198
- 2552 Views
- 775 Views
Last post by Noerty
- 1047 Views
- 11 Replies
- 6886 Views
Last post by ZuluR
