2006 v70 2.5 turbo Topic is solved
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
MDK
Year and Model: 2004 S60R
Been thanked: 41 times
2006 v70 2.5 turbo
Post by MDK »
No Zion .. not a miss fire per se.. no codes.. it was just something I found.. I think I'll go down to the junkyard and see if I can pull a coil pack wiring harness assy off of one before they crush it. They crush em 2 fast here in Cincinnati.. if those dumb @$$es only knew how expensive the parts R.. do I give them heck? Yeah, it's my job
jonesg
Year and Model: 2004 V70
Has thanked: 70 times
Been thanked: 483 times
Post by jonesg »
if you have no luck finding parts those plugs can be rewired once you see how the pins release.
MDK
Post by MDK »
It's not really the plug end.. I know what you mean though. The oil fill cap leaked and I pulled the cover off.. oil everywhere. I dried up the top of the cylinder head with paper towels, but the wires, wire loom are oil soaked. So I just wonder where the entire harness for the coils plug into.. I'll have to just trace it back and see what's what..
jonesg
Post by jonesg »
the wires go into the loom, you have to cut and patch in new wire.
MDK
Post by MDK »
I cleaned #4 coil wires with electronics cleaner and wrapped them up individually. I think 1 might have been going to ground on the cylinder head. Mopped up the oil and replaced oil fill cap with a factory one ( says Volvo recommends Castrol) with new gasket. I think the PO used cheap gas or low octane. I put some 94 octane in it from Shell and ran it ! When I changed the oil it smelled a little like gas..
