Oetiker clamp pliers.....what kind to get?
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 117 times
- Been thanked: 271 times
I'm soon to embark on replacing my PCV system and want to use the correct oetiker style clamps. I need to get some good pliers that will enable me to secure oetiker clamps in tight locations. The standard Knipex looks like it probably wouldn't fit in some areas where I will need to secure a clamp. Also the Oetiker brand looks to be too big. Any suggestions? I found a source that sells the Oetiker clamps locally individually but need advise on the plier. Thanks!
2003 XC 70 (sold)
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
double hinged versions apply more force with shorter handles,Blacklab467 wrote: 04 Jan 2023, 14:16 I'm soon to embark on replacing my PCV system and want to use the correct oetiker style clamps. I need to get some good pliers that will enable me to secure oetiker clamps in tight locations. The standard Knipex looks like it probably wouldn't fit in some areas where I will need to secure a clamp. Also the Oetiker brand looks to be too big. Any suggestions? I found a source that sells the Oetiker clamps locally individually but need advise on the plier. Thanks!
standard plumbing style are cheaper because they use a single hinge but longer arms.
I have the cheap ones for pex water plumbing in the house and air lines in the garage.
They require a lot of force, cheater pipes on the handles sometimes.
The $57 bellmetric is far better than the other $30 versions.
- 14 Replies
- 1612 Views
Last post by BEJinFbk
- 2198 Views
Last post by prwood
- 707 Views
Last post by MoVolvos
- 28 Replies
- 4623 Views
- 522 Views
Last post by firstv70volvo
