1997 850 GLT (LPT) 200K miles
Car is down on power, acting like my old NA 850. Fuel mileage has tanked.
I can hear what sounds like boost pressure leaking from somewhere when I am accelerating.
Not seeing any bad/blown hoses from the turbo to intercooler to TB intake.
Do intercoolers even go bad? I'm see a small hole (factory?) with a smudge of oil around it at the bottom low point of the intercooler. Weep hole ???
I attached a vacuum/pressure gauge to the vac. tree (no stock "boost" gauge) and I get a reading of around 18" of vac. at idle, 9" at cruise & 0" of vac. at WOT, normal?
Gauge never registers any real "boost".
Is there an easy way to attach a gauge to measure actual/real boost pressure ??
Sort of sounds like the wastegate is stuck open, but I don't think that's it.
Bad bypass valve ?
Can't reproduce the sound unless under load (driving).
Will fabricating a way to manually add some low PSI to the TB intake hose be a viable way to listen for a leak ???
What are the most likely places I should be looking at.
Thanks
Peter
missing my boost
- Has thanked: 2857 times
- Been thanked: 1332 times
A boost gauge is good for problem solving/data and just plain fun. Here's my boost gauge install DIY from 11 years ago. Your boost numbers are normal, however... roughly 10psi under WOT is in the neighborhood for a correct number for LPT if I recall correctly.
Yes, intercoolers do fail. Weep holes are normal. You wouldn't be getting that high boost if your IC has a big hole somewhere, so it's not that.
hausmeister
- Year and Model: 1995 850T5-R
- Has thanked: 276 times
- Been thanked: 84 times
Sounds like a boost leak or some kind of hose failure. Check the hoses or get a pressure tester... a hose can split and it is not obvious unless under pressure, for example.
850 T5-R '95 auto
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
Chased similar problem before finding out that my intercooler had a crack, so yes they do fail. Particularly the stock unit with the plastic tank. It took a smoke test to find it.
1999 V70 GLT
1999 V70 GLT
I'll fix them tomorrow, 67. Sometimes the forum software gets rotation wrong...
Photos fixed.
Great DIY leak finder tool! I love it.
I'm confident you'll find it's one of the vacuum lines or elbows.
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
Cotton balls, ah ha! My son and I made one with oily rags in a paint can. The hose got hot, kinked, and it blew the lid off the can!
67Amazon
- Year and Model: 122S 1967
- Been thanked: 2 times
Good news, Bad news
Good news, I found the leaks, bad news, I found the leaks.
need both a new radiator & intercooler.
smoke test reveled a leak from somewhere on the upper left-side of the intercooler (couldn't see exactly where).
pressurizing the cooling system with the test cap revealed a small leak at the bottom right side-tank seal.
- 21 Replies
- 5440 Views
Last post by j-dawg
- 11 Replies
- 1606 Views
Last post by erikv11
- 694 Views
Last post by cn90
- 13 Replies
- 2483 Views
- 1304 Views
Last post by Florida Wheel
