2006 S60 2.5T AWD: how much force is needed to secure a compressed coil spring (for safety purposes)?
FMradio
Year and Model: 2006 S60
Has thanked: 55 times
Been thanked: 8 times
Post by FMradio »
Hi :)
In the future, I will be assembling new front strut assemblies for my car from the individual parts (reusing my old springs), so I'll need to use a spring compressor to compress the coil springs for assembly. I've familiarized myself with some safety info about using a spring compressor.
I've heard horror stories of spring compressors failing and letting a compressed spring jump out and cause injuries. I would like to add ratchet straps onto the springs while I am compressing them as a failsafe to prevent the spring from rocketing out if the spring compressor somehow let go. (Heard this idea online)
Would a ratchet strap with 10,000 lbs breaking force, or 2 ratchet straps with 5,000 lbs breaking force be able to keep a compressed Volvo S60 coil spring from springing out and hurting me? I grabbed the 10,000 lbs figure off of a Jeep forum https://www.cherokeeforum.com/f67/compr ... ap-105362/ though it's a completely different vehicle so it may be totally irrelevant.
Thank you, Andy
Has thanked: 1610 times
Been thanked: 4065 times
The good spring compressors have safety retainers that prevent the spring from getting away, like this one
https://www.amazon.com/ABN-11-5-Strut-S ... NrPXRydWU=
For about $50 you can get the next model up with a positive spring clamp.
Using straps is better than nothing, but a shock rating isn’t likely to be as high a static load fading, figure a factor of 3x less.
You can estimate the compression load by measuring spring compression on car, loaded and unloaded, then using Hookes law to determine the rough spring constant
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
$80-100 on ebay. One of the best garage tool investments.
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
I use 2 sets of compressors. You can fit 3, even 4 compressors on the regular springs.
I posted some photos in forum (S60 and XC90).
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
I have these. They grab the coil with a locking pin so it can't slip out or off.
