Is it at all reasonable to drop the transmission fluid pan on a 2000 V70? My goal would be to do a very thorough fluid change, removing any metal bits which might be there. My transmission is so bad I think it could use that level of care.
I just did the transmission fluid change on my 2016 Mercedes E350. It's designed to drop the pan, letting you change the large fluid filter, clean the magnet, and wipe everything down of fine carbon particles. Would really love to give the V70 that much cleaning.
Drop transmission pan?
- FireFox31
- Has thanked: 159 times
- Been thanked: 303 times
FireFox31
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
If your trans is already a bit rough, it's generally not advisable to do a full flush or aggressive cleaning. The most recommended method would be to do a series of "drain & fills". Drop the drain plug, usually about 3.5 quarts comes out. Refill with the same amount and do this 2-3 more times with some driving in between. It'll gently clean out the transmission without the shock of all new fluid instantly.
I've also run a Magnefine inline filter on mine, since there is no filter stock. Been using them for 100K+ miles with no issues. In the past, when I've opened them up, it's easy to see they've done a really nice job of attracting metal particles with the magnet.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
Pulling the plug and having a hard look at the fluid will tell you as much as removing the pan on these cars. Stick a magnet in the bottom of your catch receptacle, it will gather the ferrous bits. I've used Robert's (and others) method of disconnecting the cooler line and pumping the remaining old fluid in stages - after the initial topoff after unplugging.
- 28 Replies
- 11726 Views
- 28 Replies
- 10056 Views
Last post by SuperHerman
- 22 Replies
- 3323 Views
Last post by volvolugnut
- 1002 Views
Last post by Matty Moo
- 1007 Views
Last post by dux02v70
