Can I Test My ECM?
Oka
Year and Model: XC70, 2001
Has thanked: 9 times
Been thanked: 4 times
Can I Test My ECM?
Post by Oka »
Audew Jumper.JPG (3.51 KiB) Viewed 383 times
Went to jump start the 2005 XC90, V8, connected the jumper; the positive to the positive connector next to the fuse box in the under the hood, and the negative to the strut stud. This is how I have always jump started cars, with this jumper. This time around, as soon as I connected the negative, I heard a "chukuum", and I immediately let go without any more connection. The only thought that came to mind was that my ECM got fried. When this happened, the jumper was at 98%; it went down to 0%. That is serious !!!
Isn't my connection the right way to jump start a car? I have been jump starting cars with this unit a lot and in the same format. Checked and the manual specifies connection the negative to the engine frame, if using a donor car.
What did I do wrong?
There should be a way I can at least test mine to confirm it is the ECM, any DIY test I can do? A replacement would be $728.
Cheers
chitownV
Year and Model: 2008 XC90 3.2
Has thanked: 15 times
Been thanked: 40 times
Post by chitownV »
The ECM shouldn’t be active until you turn the key. Double check your jump starter as it sounds like its internal fusible link burned out or an internal fault; this can happen as the starter packs are made with a certain price point.
Have you tried connecting a battery charger, using regular jumper cables, or another jump starter pack?
2008 XC90 3.2 AWD - 169k miles, Premium, Versatility 7 passenger, Climate, Convenience, retrofit Morimoto D2S HID bi-xenon, iPd swaybars & poly bushing inserts, Powerflex poly control arm bushings, Bilstein Touring Fr struts, Continental CrossContact LX25 255/55R18, Fr Infinity tweeters & speakers, hardwired cheap $17 Bluetooth to center console aux & pwr, CQuartz UK 3.0 ceramic coated, no oil consumption using Mobil 1 0W-40 even w/ my lead foot
Oka
Post by Oka »
chitownV wrote: 26 May 2023, 11:04 The ECM shouldn’t be active until you turn the key. Double check your jump starter as it sounds like its internal fusible link burned out or an internal fault; this can happen as the starter packs are made with a certain price point.
Your first line made me think of just putting back the charged batter and check the car, just for the fun of it. I did, with the key in the number 2 position, bam, I heard a little click saw the security light come on. I thought it was a joke. I went in, turned the key and it started. I was so excited I was besides myself. Thank you so much for your directions, you just saved me $728. I really appreciate your thoughts. I asked the ECM people how I can test the ECM to make sure it is culprit. I have to send it to them to test for me, which is not cheap for me from Anchorage, Alaska.
In the past, I brought up the style of replacing the battery with the key in the number 2 position. I saw it in one my the Volvo manuals. I have always done so, but not when this issue happened to me.
Now, in the manual, it only shows the process of jump starting the car with a donor car, but not with a battery pack. I have always connected the negative clamp to the strut stud. Is that wrong instead of on the engine block?
I see you live in Maryland. Looking at your signature, you use Mobil 1, 0W-40; is that all seasons? You have winter season there also, right? Just curious.
Also what would you mean by having a "lead foot" with respect to the oil weight you use? What has speed got to do with your oil type.
See, I never stop learning about things.
Thanks
chitownV
Post by chitownV »
Glad you figured out the issue and it wasn’t an expensive ECM.
Yes, in Maryland and used to live in Chicago. I use 0W-40 year round and it does very well. My lead foot is how hard I push the pedal, thus how hard I push the engine, and I don’t consume oil at my high mileage.
You can learn more about A3/B4 oils and how they do very well in the XC90 engines.
https://www.swedespeed.com/threads/oil- ... st-8046070
Oka
Post by Oka »
chitownV wrote: 26 May 2023, 20:36 Glad you figured out the issue and it wasn’t an expensive ECM.
Thanks!
