Hi all
I have a problem where absolutely no climate related functions work. NO heat, cooling, fan,dampers, demisters etc.
It started out as intermittent a few months back, but now is permanent.
Radio and Car Setting controls work but can be very glitchy. All backlights and some button/ knob lights are flashing also.
I don't have Vida or Dice.
A dealer diagnosed " No Communication" . They visually checked the wiring and plugs and recommended CCM swap at about $1.5x the value of the car. I unplugged and replugged everything from the CCM and CEM with no change. No obvious pin, corrosion, wiring pinch, water or any other problem I could see. Jiggling plugs and looms has no effect.
I am looking at sending the module to XeMODeX for repair. Is this likely to fix the issue?
I've had this car for a few years now and really loved it until I had this problem. It makes me really mad that I can't just swap the module with a readily available second hand part.
Any help gratefully received.
Cheers,
James
2009 V50 CCM "No Communication" fault. Topic is solved
nincomjool
- Year and Model: 2009 V50
- Has thanked: 1 time
- Krons
- Has thanked: 198 times
- Been thanked: 215 times
Sending to XeMODeX is your best bet.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- 653 Views
Last post by nincomjool
- 3881 Views
Last post by Blacklab467
- 9060 Views
Last post by danlemac
- 2468 Views
Last post by TripleThreat719
- 3427 Views
Last post by SSaxman
