If the supports for your heat riser box have gone to entropic heaven here is a cute fix with a pretty cheap hardware store part
3.5 inch on center , 4.5 inch deep u bolt , slightly bent in to clear holes in tin
P80 NA heat riser manifold fix
- Has thanked: 1504 times
- Been thanked: 3817 times
- IMG_5459.jpeg (664.76 KiB) Viewed 266 times
- Has thanked: 1847 times
- Been thanked: 1710 times
What is a heat riser? It is not a term I am familiar with.
It’s this guy….
- IMG_5459.jpeg (664.76 KiB) Viewed 245 times
- IMG_5458.jpeg (711.76 KiB) Viewed 245 times
- IMG_5462.jpeg (740.28 KiB) Viewed 245 times
- Sveedy
- Has thanked: 417 times
- Been thanked: 457 times
Remember way back in the day with V8's that had a corrugated tube that ran from the bottom of the air cleaner down to the exhaust manifold ? That is your " heat riser ". It was just to help warm up the fuel system in cold temps, by letting the heat rise up into the air cleaner, and get the choke off.
1999 V70 GLT
1999 V70 GLT
OK, pre-heat tube. That I know well, and only on NA's as per abscate's note. I still never understood why this was not added to the turbos which is what really needs it when it is cold up here as the intercoolers can freeze!
- Has thanked: 292 times
- Been thanked: 765 times
Adding heat to the intake path on a turbocharged engine is anathema!
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
I managed to ice up a turbo throttle body exactly once in my life. HPT slow running in winter. Never happened again.
Up here P80's can suck the intercooler pipes flat trying to draw air through a frozen intercooler at -40C. Cardboard blanking plate behind the grille and parking the front of the car downwind can also help along with a block heater. You know this has hit you when you put the car in Drive or Reverse, press the gas peddle and the car does not pick up revs or move! Only way to fix is to let the engine run and defrost itself.
- 1141 Views
- 341 Views
Last post by Flyingdutchman
