2002, V70 Horn wiring
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Mr. Detail
Year and Model: 2002 V70 N/A
Has thanked: 151 times
Been thanked: 4 times
Post by Mr. Detail »
Okay, I need an electrical wiring SME (Subject Material Expert) here for this question.
I have had a pair of extra loud PIAA horns sitting in my garage for I don't know how long and really want to install them.
I took a couple of photos today while under the car and changing my oil. The original Volvo horn has a plug on it with that plastic protective stuff around the outside while my new PIAA horn has two separate contact points. Any idea how I can re-wire this so my old, existing wiring will work on the new horns? I am bad with wiring stuff. (See attachments of both horns)
Existing original horn.jpg (182.22 KiB) Viewed 216 times
New PIAA horn.jpg (158.98 KiB) Viewed 216 times
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 481 times
Post by jonesg »
soldering iron, heat shrink etc.
Mr. Detail
Jonesg,that does not help with the actual wire color and which wire goes to which tab.
jonesg
Post by jonesg »
its not as if the engine blows up if you get them reversed, try it and find out.
It should work both ways because the connector tabs on the new horn are not 'keyed'.
Worst case is you pop the fuse.
