2013 C30 A/c Stopping then starting after awhile
BlackThunder
Year and Model: 1997 850
Has thanked: 6 times
Been thanked: 3 times
Post by BlackThunder »
Hello, my C30 's A/C was working well but in the past couple of days (since it has been over 100F) it has blown cold air then the fan keeps blowing but it isn't cold. Then I turn off the A/C for about 5 minutes and turn it back on and it blows cold again.
Any ideas? Does this mean I need to do an A/C refrigerant charge? Anyone remember what type I'm supposed to use? The local store sells it unless they have gotten rid of that summer stuff :lol:
Dustin
Dustin
2013 Volvo C30 T5
1997 Volvo 850 NA Sold to a New Volvo Enthusiast
theWIFES_S70
Year and Model: 1998 S70 base
Has thanked: 61 times
Been thanked: 37 times
Post by theWIFES_S70 »
Same happening on my 07 S40. Took it to a local Volvo shop and they shrugged their shoulders and said, just shut it off for a few mins and turn it on later. We've been doing this for the past two years. It's a Volvo so it probably need a completely new A/C system... and have you see what it takes to replace these heater cores???
Retired:
2015 Volvo S60, T5, 85K
BlackThunder
Yikes! Yeah, I was thinking about cleaning the cabin air temperature sensor. That part is less than $50 but it could just be dirty. I'm going to start with that then see if it helps. It's the little sensore behind the waterfall that has a like 3 or for lines cut out of it in the dash.
I remember it was dirty once before and I just vacuumed it but didn't know what it was.
🤞 That works.
Dustin
Dustin
2013 Volvo C30 T5
Krons
Year and Model: 08S60 05XC90 02S60
Has thanked: 198 times
Been thanked: 215 times
Post by Krons »
The issue is likely your AC compressor clutch gap. Easy to diagnose and short term fix with some zip ties to effectively shim the gap a bit tighter. Easy to do on P1 chassis cars as the compressor can be accessed by pulling front right wheel.
Thread on it here:
viewtopic.php?p=631221
Longer term fix (not my video):
08 C702.5T (sold)
The non-Swedes:
