PCV Check valves
- C1ph3r
- Year and Model: 1999 V70T5
- Has thanked: 32 times
- Been thanked: 7 times
99 V70 T5 - So when I did the PCV overhaul last year I didn’t do the Evaporative Emissions Hose from Volvo with the 2 little white check valves. That hose is crazy expensive so I just replaced the rubber parts. Are those little white valves something that can be replaced with a more universal check valve? Wondering if I need to replace it.
1999 Volvo V70 T5
1970 Chevrolet C10
2006 Acura RSX
2016 Subaru Impreza
1975 Honda CB360t
1970 Chevrolet C10
2006 Acura RSX
2016 Subaru Impreza
1975 Honda CB360t
- Has thanked: 2203 times
While still expensive, the part is way cheaper from Tasca at around $85 US, v's FCP @ $118.
I am not sure if those small valves are available separately. I would have thought so, but I'll need to check.
Is this the valve you are looking for:
https://www.ebay.ca/itm/204136768968?ch ... 9hEALw_wcB
- Been thanked: 4068 times
Just test them by blowing into them
White to black , air flow
Black to white, no flow
- C1ph3r
thanks guys. mine are all one color. I did do the blow test when i replaced all the rubber line when I did the PCV system.
not sure if those linked to are the same but seems to me a one way check valve is a one way check valve. I may look into those linked to.
After shipping its only $7 less from Tasca. Might as well get it from FCP if I do when I order all the other mess I need.
thanks,
A.W.
thanks,
A.W.
1999 Volvo V70 T5
1970 Chevrolet C10
2006 Acura RSX
2016 Subaru Impreza
1975 Honda CB360t
1970 Chevrolet C10
2006 Acura RSX
2016 Subaru Impreza
1975 Honda CB360t
- 1065 Views
Last post by wizechatmgr
- 586 Views
Last post by Olegs855R
- 647 Views
Last post by Earn_est_89
- 1359 Views
Last post by xHeart
- 1406 Views
Last post by nsjames
