S60 '01 Speedo ABS CEM??
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
bepilot
Year and Model: 2001 S60 2.4T
Has thanked: 2 times
Post by bepilot »
Hello all,
My french 2001 Volvo S60 2.4T is throwing a tantrum since it approached the 200k km mark in June and I haven't been able to track the failure down, but mandatory technical inspection here in France is coming up next summer and it won't pass for sure with the errors on the dash I guess (I can always remove the bulbs but that's not how it's done) - selling on will be an issue too if non resolved :roll:
So what are the issues? (they came in bit by bit in 1 month let's say, but are now permanent):
- BRAKE FAILURE Stop Safely on dashboard with the orange triangle
- Speed indicator does not work, no mileage is added on trip meter or clocked up in general, rest of dash is ok - no cruise control in these conditions, so thanks Waze and free mileage rollback :D
- ABS - Brake - DSTC light on dash, these light on permanently 5 secs after startup
- Engine management light on (which I can reset with my cheapo OBD2 checker, but engine acceleration is 'jerky' then so I avoid it) - power seems slightly off.
After some googling I cut open my ABS-unit (and redid the soldering whilst I was at it - it looked pretty ok otherwise) but to no avail - another google-search with the serial number on it 8619466 said this one was not affected by cold solders ?? It's a DSTC unit btw.
Then I pulled the CEM to the bare pcb and nothing seemed fishy over there too, difficult to see as all is coated in a brownish sealant.
With the battery disconnected for about 3 days, it worked 300kms, but alas - symptoms reappeared and they never went away.
Battery resets are now to no avail (it was replaced this summer for a non related issue)
So I left my car at the Volvo dealer whilst in Belgium last week as I don't have Vida, and here's the printout:
The old&bold technician told me track all wiring CEM-BCM and wished me good luck after requesting 78€ for the read-out...
Main issues are CEM-1A5E and CEM-1A5F , which appear SAS and BCM related.
Other alarms seem pretty normal to me, I run a custom E85 tune so I guess that pops some ECM-messages - the vacuum lines are getting krusty so I'll have to replace those (and that Pierburg valve-thingy too?).
I changed the clutch pedal sensor once when cruise control acted up when I got the car 4 years ago, but again one brush of the resistance track inside broke off so that throws a code too (ECM-9300).
I also replaced the ETM with the contactless Sacer one, which got rid of some acceleration stumbling issues 2 years ago.
And the siren fuse was pulled for internal battery reasons (UEM-0004)
Plan of action:
- check ECM power relays as xemodex recommends (even if my car is from 2001...):
https://xemodex.com/us/bcm-diagnostic-f ... -s80-xc90/
How do you check these?
- have a little clean of the SAS: https://www.youtube.com/watch?v=Oc-RIK8rdzI with https://www.swedespeed.com/threads/stee ... or.662505/
What would you tackle, or think? I'm planning working on it tomorrow. I secretly hope it's just a silly speed sensor issue as there is also the ECM-510F fault which is related to this, but the resistances in the speed sensors seem to correspond to around 6K ohm. Is there a sensor on the (manual) gearbox too?
I'll keep this updated so this can help someone out (that's why forums are for) - thanks for any advice on this pesty fault
2001 S60 2.4T manual
It's not 'tuning' we're after, it's 'continuous improvement'...
yanga001
Has thanked: 59 times
Been thanked: 110 times
Post by yanga001 »
Buy a dice or get a chinese knockoff (i use a foxwell series for volvo NT510 Elite although there are newer ones now) to get your own codes. Freeze frame data would be extremely useful here as we could tell if its intermittent, at startup, at speed, or in a certain gearing.
2008 S60 2.5T Auto (Sold)
bepilot
Post by bepilot »
I have a very cheap OBD2 scanner (Autophix OM123) - it outputs P1633 for the mishap which relates to the ECM-510F vehicle speed signal fault, and it's all the info I got. It's however a good tip to check if I get the speed through the scanner, you never can tell indeed.
Concerning the plethora of current OBD2 scanners on the market, it looks like a jungle out there to make a decision purchase - knowing i want to swap the Volvo for a NA 6 cylinder BMW E90 afterwards (yeah, I want rwd again) I don't want to be stuck with a one make thing.
bepilot
Post by bepilot »
bepilot wrote: 27 Nov 2023, 09:27 - check ECM power relays as xemodex recommends (even if my car is from 2001...):
- UPDATE -
Well after spraying contact cleaner on all ABS-plugs and BCM-ECM connections, with battery reconnected all seemed working again except radio, 12V plug sockets and passenger seat controls...
I then stumbled on this thread viewtopic.php?t=75241&start=20 which then pointed the CMA2 relay plugged on the CEM board. Indeed, swapping the position of these 2 main relays and the problem switched, so clearly one relay was faulty. I replaced it with a 50A I had laying around and for the moment, speedo-abs is working again satisfactory since a week which included a big journey.
The only message remaining is Airbag SRS related, but as I haven't cleaned the SAS this time, this will have to wait - looks like my remote control is also acting up weird, I can't seem to unlock when the car is cold, so yeah :mrgreen:
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 481 times
Post by jonesg »
good job, you need a better code reader to erase the SRS.
bepilot
Post by bepilot »
Ah pity… I touched the battery cables for a full reset each time so this one remains in the memory nevertheless? :cry:
Guess I’ll invest then, I’m bored paying Volvo 75€+ each time for their vida hookup…
jonesg
Post by jonesg »
get a decent scanner that will do volvo and other cars.
