Hi all,
I'm looking for assistance diagnosing a noise coming form the engine bay:
It's a cyclical "chh-chh-chh" noise that only appears with foot on the gas while moving (it doesn't happen when revving in Park or Neutral at a standstill) and it doesn't disappears when coasting. Its frequency increases with speed. It seems to go away at higher speeds, but it may just blend into a constant noise with the rest of the normal car noises. No noticeable performance issues.
My problem is I can't find the source because it only occurs while moving (with foot on the gas)...
Any leads would be appreciated!
Thanks all.
Help: What's something that spins only when moving AND supplying gas?
WestCoastWagon
- Year and Model: 2004 XC70
- Has thanked: 9 times
- Been thanked: 5 times
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
It could possibly be an exhaust leak, like a manifold gasket or turbocharger connection, etc.
Can you duplicate the noise when at a stand-still by firmly holding the brake pedal down, putting it in gear, and giving it some throttle? (Increasing engine load)
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
in mine it was a bent dust guard behind the brake disk.
i found it by putting the front wheels on jackstands, disabling the rear by removing the haldex fuse, start engine, put in drive and let the wheels spin. if its in the drivetrain you should be able to track it down.
- Has thanked: 987 times
- Been thanked: 1078 times
This is good method to trace the noise.jonesg wrote: 18 Dec 2023, 04:14 in mine it was a bent dust guard behind the brake disk.
- 1744 Views
Last post by darrylrobert
- 810 Views
Last post by Ozark Lee
- 2558 Views
Last post by sparky77
- 20 Replies
- 5334 Views
- 947 Views
Last post by SuperHerman
