Gas needle stays hovering near full 06 s60
chris11211
Year and Model: 2006 s60 2.5T
Has thanked: 7 times
Been thanked: 29 times
Post by chris11211 »
Had my gas near half the other day, but then i noticed today that my gas is now near full. On occasions the needle will go down one notch, and also no one else drives.
I'm not sure if I should change the whole fuel pump or just the other lever sensor, and if there's a way to tell when i am low on gas for easy repairs. Thoughts?
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
stuck float ?
bang the tank with a chunk of 2x4.
chris11211
okay, so this is just a one off event and I shouldn't bother changing?
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Actually,
A bottle of Techron (or Lubro Molly) FI cleaner every
2-3 months should clean up any deposit on the floater.
chris11211
So when I started up again this morning the needle was near half, but as the car started warming up it started to go near full on its own.
Edit:
So I managed to get into the driver's side fuel level sensor on top and I managed to tap on it with a ratchet and now it seems the level is correct, but still should I bother with replacing it? It seems very cheap. Or should I just throw in a techron?
