Hey, i have a problem with my transmission, it is leaking from the weep hole and from one other place aswell, i don't know what it is called.
It happened right after i drifted a little bit on the snow, a lot of transmission oil just leaked out on the ground, i checked the dipstick right after it happened and it was bone dry. Pulled it to a garage, checked the dipstick 2 days later (with a cold engine and transmission) it was even over the HOT line. How is this possible? What could be the explanation?
V70 2.5T AWD transmission leak
reigox
- Year and Model: 2004 v70
- Has thanked: 2 times
- oil11.jpg (206.4 KiB) Viewed 526 times
- oil.jpg (278.04 KiB) Viewed 526 times
- MoVolvos
- Has thanked: 310 times
- Been thanked: 524 times
Are you checking with the engine running or off? Checking when hot or cold will show level differences on the dipstick also. I believe you should be check the trans fluid when with engine on. Be sure it's not engine oil per "jonesg". Transmission fluid is not that thick and has a different flow characteristics. That's why it's transmission fluid not oil as in motor oil.reigox wrote: ↑25 Dec 2023, 17:17 Hey, i have a problem with my transmission, it is leaking from the weep hole and from one other place aswell, i don't know what it is called.
Lastly, do a smell test.
- MoVolvos
Did you drift into anything? The first thing you can do is try a bottle or two of a seal rejuvenator such a AT 205. If the problem is lessened then you know it's a seal otherwise something cracked or a hose somewhere perhaps. Without digging around the engine bay from the top to bottom and checking the lines of the transmission I would say your guess is as good as mine.
vtl
- Year and Model: 2005 XC70
- Has thanked: 114 times
- Been thanked: 606 times
ATF fluid level check is performed with the engine running.
The explanation could be the last guy who changed the fluid didn't know how to do it right and overfilled it. Warm it up, check the level. MIN is where it should be at 40 degrees Celsius, MAX is at 80.
