Cold engine one cylinder misfire
Hi guys, I have a Volvo s60 T6 2017, 80K mileage. Got a misfire on the 3rd cylinder (PO303). It happens every time after starting up while the engine is cold; it's all good after it warms up (checked with live data from OBD). Potential issues with the ignition coil and plugs have already been excluded. Short- and long-term fuel trims are also okay. I am pretty sure there is a very narrow list of possible root issues. I would appreciate any suggestions. My last suspicion is an Injector, but warming up will not fix it in that case, right?
- Has thanked: 927 times
- Been thanked: 1000 times
Connector, power, ground issue with plug or injector at #3 cylinder?
How were plug and coil problems excluded?
