Hi all,
Just picked up an iCarsoft scanner and have been using the realtime data feed to monitor misfires while driving my 2005 S80. During about an hour of driving, i'm seeing a small number (1-2) of misfires on random cylinders. No check engine lights though. Rookie question, but is it normal to see occasional misfires like this?
Misfire threshold?
- pgill
- Year and Model: 2010 S80, 2008 LR2
- Has thanked: 120 times
- Been thanked: 189 times
Sort answer: yes this is normal
Good luck
Paul
viewtopic.php?t=87687&start=160Here is an example (actual data from my S80)
Misfire counter
EWMA = Exponential Weight Moving Average (This is effectively the average for the last 10 times you started the engine)
Last = The most recent time you used the engine (if you check the data before you start the engine it is the number of misfires from the last time you started the engine and it resets to zero as soon as you start the engine)
Here is my data for the S80 that I collected before starting the engine
Cylinder..........EWMA (counts)..........Last (counts)..........
Cylinder #1..............1.........................0..........
Cylinder #2..............0.........................0..........
Cylinder #3..............1.........................0.........
Cylinder #4..............0.........................0..........
Cylinder #5..............0.........................1..........
Cylinder #6..............1.........................1.........
These are obviously very low misfire counts.
Good luck
Paul
- pgill
Here is some more information
Typical Misfire malfunction thresholds
Malfunction criteria........................Threshold value
FTP Emission threshold................> 1.5 % (4th exceedance or exceedance in first 1000 revolutions)
Catalyst damage threshold...........8 - 25 %
For example if you are driving at 1800 rpms for 30 minutes (6 cylinder)
1800 * 6/2 = 5,400 ignitions per minute
5,400 * 30 = 162,000 ignitions in 30 minutes
1.5% of 162,000 = 2,430 misfires
Conclusion: the MIL light is very late. I would do something about 200 misfires.
Just my $0.02
Take care
Paul
Just my $0.02
Take care
Paul
- 4829 Views
Last post by chitownV
- 591 Views
- 19 Replies
- 10205 Views
Last post by Barledge
- 2500 Views
Last post by Ryanxr400
- 941 Views
Last post by stephansvolvo
