Hi all, I bought this car almost a week ago now and the tailgate has never opened in that time. The electric lock seems to be functioning, as it goes moves from the locked to unlocked position with the rest of the car.
Symptoms are:
-Tailgate wont open from inside or outside handle
-"Tailgate Open" indicator on dash has been lit up throughout this entire ordeal
Already tried:
-Locking and unlocking tailgate directly with key, while pulling/pushing on handles
-Pulling handle up while pushing down on tailgate
Finally got around to spending more time diagnosing the issue today. Ended up removing the two t40 screws that hold the metal bracket that the latch grabs on to, to see if I could get a better look at it that way. After propping the tailgate open (lift struts are dead), I still couldn't figure out how to release the latch from the metal bracket. Any insight would be greatly appreciated!
1998 V70, Tailgate latch stuck in closed position
- jnitschke123
- Year and Model: 2006 V50 T5 AWD
Current:
2006 V50 T5 AWD 6 speed - 240k Kilometers
Gone:
1995 850 GLE Wagon, 10 valve - 190k kilometers
1997 850 T-5 Wagon, ex-US car - 225k miles
1998 V70 SE Wagon - 300k kilometers
Gone:
- Has thanked: 311 times
- Been thanked: 817 times
This is (unfortunately) common, the latch mechanism is plastic and a piece inside is likely broken. Check this thread for discussion:
https://www.matthewsvolvosite.com/forums ... hp?t=65078
- jnitschke123
Looks like a replacement used latch would be a decent temporary fix. However, I still need to remove metal bracket that the latch grabs on to, so I can actually remove the latch. Should I just hacksaw it off?
Current:
Gone:
Gone:
I don't remember how, but I was able to remove the metal bracket once I opened the liftgate. Lots of fiddling with levers. Wait until your replacement arrives and inspect carefully how it works, that may give you the clues to opneing the one currently in the car, since you want it intact to close the gate in the meantime. I think I would destroy the latch mechanism before I cut the bracket piece.
- 5164 Views
Last post by foggydogg
- 2939 Views
Last post by arne27
- 15737 Views
Last post by Medusalith
- 13 Replies
- 1440 Views
- 1901 Views
Last post by matthew1
