Volvo C30 T5 Check Engine Problem
I own a 2012 Volvo C30 T5 and 'for some time that I try to solve a problem, it appears on the dashboard CHECK ENGINE but when I connect the ECU to the diagnosis it appears SOFTWARE PROBLEM but it does not specify what, the car turns on and goes regularly, I have changed the downpipe and cat with a 200 cell, and hop asked an electronic to inhibit the lambda sensors but after a while the sp0ia CHECK ENGINE came on, could it be due to a job done badly??
precisionguesswork
- Year and Model: 2008 C30
- Has thanked: 11 times
- Been thanked: 16 times
If you changed the downpipe and with a 200 cel cat you need to have it tuned.
I have done it with a Electronic tuner, but maybe not properlyprecisionguesswork wrote: ↑05 Jun 2024, 23:16 If you changed the downpipe and with a 200 cel cat you need to have it tuned.
- 1611 Views
Last post by aewoodhouse
- 1139 Views
Last post by Pretribrapper
