Ridiculously low asking price…
Body and interior looks almost pristine, and it has 164k miles. Owner says it has a P0607, and will not start. Says it just clicks and was told there might be a battery cable issue.
I have a V70 2.4T with 300,000 miles, and ViDA, so Volvos are not new to me, but I’ve not done anything with an XC90.
What should I look for/be concerned about?
Thanks!
Jonboy
Considering a non-running 2007 3.2 - what to look for?
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
.Jonboy74 wrote: 05 Jun 2024, 15:39 Ridiculously low asking price…
Thanks!
Jonboy
One forum says 11 codes to the P0607 and this UK forum lists those. Since it clicks it could be just the battery while another forum said crack coils. Could be a number of things so need to check with ViDA.
https://www.volvoforums.org.uk/showthread.php?t=282782
P0607 -- ECM-9800 -- Engine control module (ECM), torque signal -- Internal fault
P0607 -- ECM-9810 -- Engine control module (ECM), engine rpm -- Internal fault
P0607 -- ECM-9820 -- Engine control module (ECM), load signal -- Internal fault
P0607 -- ECM-983B -- Engine control module (ECM) -- Internal fault
P0607 -- ECM-983C -- Engine control module (ECM) -- Internal fault
P0607 -- ECM-983D -- Engine control module (ECM) -- Internal fault
P0607 -- ECM-9840 -- Engine control module (ECM) -- Internal fault
P0607 -- ECM-984B -- Engine control module (ECM) -- Internal fault
P0607 -- ECM-9860 -- Engine control module (ECM) -- Internal fault
P0607 -- ECM-720B -- Engine control module (ECM) internal fault -- Signal missing
P0607 -- ECM-9850 -- Engine control module (ECM) -- Internal fault
towerhill
- Year and Model: '08 XC90
- Been thanked: 2 times
You know that old saying that there's no dog as expensive as a free puppy? It might apply here.
As you're thinking about an XC90 with 150k+, consider:
1) Everything to get it to Stage 1. Oil, transmission, brake, and power steering fluid and appropriate filters in an ideal case. Maybe brake rotors and pads. The minimum ante if you do it all yourself is probably $500, but easily more.
2) Anything else that might be wrong with it. Check the lower control arm bushings, which aren't cheap to replace, and tend to go bad at about that age.
3) The full 150k service is ~$700 in parts if you DIY and everything goes well, $2500 at an indy shop, and $3000+ at a dealer.
4) Whatever is going on with this code.
Point is that I wouldn't even consider it unless you're willing to toss some combination of significant time and money at it to put it right.
- Has thanked: 2857 times
- Been thanked: 1332 times
IMHO you need to want the DIY challenge, the challenge of spotting and buying a good sample, and have $1-3k, to get into first-gen XC90 Volvos.
- 1794 Views
Last post by mrscullini
- 681 Views
Last post by Jonboy74
- 696 Views
Last post by matthew1
- 1105 Views
Last post by cn90
- 1170 Views
