I discovered "fuse taps" while considering how to wire a backup camera to activate when car is placed in reverse. Any significant drawbacks of fuse taps for this application? Tapping the backup light fuse (edit: tapping the circuit, not the fuse) seems simple and would leave all original wiring intact.
2004 XC70
https://www.amazon.com/Circuit-Adapter- ... eature_div
Thanks.
Fuse tap for backup camera?
enotslim
- Year and Model: 2004 XC70
- Has thanked: 71 times
- Been thanked: 16 times
I wondered about that. Seems to me the safe capacity (at least 30a) of the circuit supplying both portions of the "tapped" circuit must be much greater than the sum of both fuses that would be used (say 10a + 5a, or even 10a + 3a).dikidera wrote: 06 Jul 2024, 10:34 Not than I can think of, except maybe if you exceed the rated amperage of the combined circuit.
Now:
2004 XC70
Then:
1972 144
1988 240 Wagon
1998 V70 T5
2004 XC70
Then:
1972 144
1988 240 Wagon
1998 V70 T5
enotslim
Update: the backup camera activates and functions fine after simply connecting the trigger wire directly to the 10a fuse for the backup lights. Not sure a fuse tap offers any real advantage beyond more secure connections (at the expense of bulk that might intefere with the covering panel). This fuse is in the cargo area making for a short and easily hidden connection. Given all this I don't think identifying and tapping into the correct wire within the wiring harness makes sense.
Now:
2004 XC70
Then:
1972 144
1988 240 Wagon
1998 V70 T5
2004 XC70
Then:
1972 144
1988 240 Wagon
1998 V70 T5
- 15802 Views
Last post by xiaofei204716
- 3079 Views
Last post by SuperHerman
- 2788 Views
Last post by RickHaleParker
- 3785 Views
- 2256 Views
Last post by babybluebug
