if he used chinese part thats the first suspect.
is it this ?
I am having trouble starting my 2003 S60 2.4L non-turbo
dikidera
- Year and Model: S60 2005
- Has thanked: 68 times
- Been thanked: 187 times
Is your model a bifuel one? If not, then it's likely a short somewhere. The electrical installation on these cars is now over 20 years old and the insulation has cracked is my opinion which is why the fuse blows. I would definitely disconnect the vacuum pump and see how the car behaves that way.
- kcodyjr
- Has thanked: 17 times
- Been thanked: 23 times
Sounds to me like he pinched part of the wiring harness doing the work, and now it's intermittently shorting to ground.
5 others that came and went
That’s on point and highly likely to be the problem.kcodyjr wrote: 16 Sep 2024, 13:49 Sounds to me like he pinched part of the wiring harness doing the work, and now it's intermittently shorting to ground.
Fault trace the fused circuit that is failing looking for bad wiring.
- 1451 Views
Last post by rspi
- 729 Views
Last post by bcole96024
- 2464 Views
Last post by kklepack
- 980 Views
Last post by CoreyD
- 18 Replies
- 7628 Views
