Moving cams when crank is at the mark
Jonesyboiii
Year and Model: 2000 S70
Post by Jonesyboiii »
Hi. I did a small error when taking off the old timing belt on my 2000 Volvo S70 B5244S with intake VVT. Previous guy had marked marked the cams himself and I trusted those marks, removed the belt and then noticed that the actual cam marks were 180 degrees off, so in this case at the 6 o'clock position. Crank was at it's correct place, between the grooves etc.
I then saw a video on Youtube from RobertDIY where he showed that it is indeed possible to move the camshafts freely, if the crank is at it's mark. I did this and didn't feel any resistance when turning the cams clockwise.
Is this ok? Could I have broken something by doing this? :D I guess problem like this is quite rare, where the person takes off the belt when the timing marks are not aligned properly. Or in this case, only the cams were 180 degrees wrong.
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
When the crank is on the mark, it is fine to move the cams as much as you want. Just be sure they are in time at the end.
Has thanked: 1610 times
Been thanked: 4065 times
I have a picture of the pistons in position with the crank in the timing mark position (this is not TDC) - I think its in my Elizabeth rebuild thread.
dikidera
Year and Model: S60 2005
Has thanked: 68 times
Been thanked: 187 times
Post by dikidera »
Not only is it possible to have the cams 180 degrees out of phase, but it's possible to torque the cam cover like that. Guess which dum-dum did that.
But yes you can fix them even like that, just as I did.
dikidera wrote: 29 Sep 2024, 15:58 Not only is it possible to have the cams 180 degrees out of phase, but it's possible to torque the cam cover like that. Guess which dum-dum did that.
I’ve got that T-shirt , too.
