New to me 1999 Sedan in beautiful Nautic Blue
97400
26.5 mpg at 65-70 DC NYC run
Radio code 6116
New battery 11-24
Tire wheel evaluation
Oil
Coolant
ATF, replaced 8 liters 12-2024
FIlters
> yanked the funky air and cabin filter and replaced with Volvo, FCP R835528362, 12-2024
Plugs
Coil evaluation
Ariane wheels
Items to work over
New turn signal switch
Drain fill ATF. 15 DEC 7 liters new @97400
Very slight radiator seep , passenger flange?
P1618 at highway speed , TC lockup solenoid?
Bulb out
2Apr25 new wiper blades. 26 mpg highway
Lock cylinder replaced
Fob and keys made at Randall
Heater core eval?
Front right tire soft?
11 aug Albany port Jeff. 150 miles, 30 mpg
No codes presented.
31 Aug new Bosch single electrode plugs , coils (original)
Slight surging on load. Turbo control valve swapped, surge gone. Ordered new TCV
Surge came back with swapped tcv a week later
Took some data on boost and throttle angle
Diagnosis here
P0440 intermittent, measured purge valve resistance at 29.2 ohms
Right top taillight intermittent- replaced bulb 1157?
Nov12 dead right front foot, bad Ariane wheel ding 195-65 15 size
Sealed rim about 1/3 circumference, moved RF to RR. - tire code 1708
Jan 2026 99350
Coolant leak ar right radiator seam? Heater core?
Check function of coolant light
Mapped ECC damper positions with knob in this thread
viewtopic.php?p=674140#p674140
Feb 13 2026 99350 replaced heater core with new Nissens
Feb 19 replaced coolant level sensor FCP removed paperclip jumper from connector 99450
viewtopic.php?t=107741
May 2026
Water intrusion into driver side footwells
Checked sunroof drains, ok
Door seals look good.
Wtf ?
June 3 2026 100,345
Oil and filter change
Installed URO air guide
replaced oil filler rubber gasket - really hard
Ripped off a real quick compression test
Warm 170-165-165-160-170, number 1 -> 5
Diagnosed ETM failure here viewtopic.php?p=679234#p679234
1999 S70 AWD 417 583998 KarlaKat Ariane
Forum rules
Please create one topic per Volvo you own. Then simply post to that topic when you maintain or repair your Volvo. You'll have a nice record of what you did, when, and how much it cost. Only you can post in your topic.
- Been thanked: 4063 times
- 08D05B24-7AAA-48B7-9892-07916CE0B1FC.png (56.01 KiB) Viewed 6358 times
- 3D082EF3-AF1E-4EA5-A494-63F9018C8BF3_1_105_c.jpeg (97.21 KiB) Viewed 6323 times
- 309999BF-0C1E-40F0-829E-EB045241BB22_1_105_c.jpeg (114.31 KiB) Viewed 6323 times
- 70423A7D-5D50-4634-A6DB-D17E486182DE_1_105_c.jpeg (143.81 KiB) Viewed 6323 times
- ID plate code for 1999
- Screenshot 2025-02-10 at 07.54.31.png (168.21 KiB) Viewed 6235 times
