Hey guys, I just changed the level sender because the gauge would get a bit erratic and then die off after about 20 min, and now after replacement it would die in about 5 min. I am wondering if its really the level sensor in the fuel pump and if I should just replace the pump as well.
Thanks!
Gas gauge still dies after replacing level sender 06 s60
- chris11211
- Year and Model: 2006 s60 2.5T
- Has thanked: 7 times
- Been thanked: 29 times
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 132 times
- Been thanked: 126 times
Any other strange DIM behaviour? I'm 2/2 of DIM's failing...
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
read the fuel level with a scanner, a cheap $12 elm327 reads mine.chris11211 wrote: 20 Mar 2025, 18:11 Hey guys, I just changed the level sender because the gauge would get a bit erratic and then die off after about 20 min, and now after replacement it would die in about 5 min. I am wondering if its really the level sensor in the fuel pump and if I should just replace the pump as well.
Thanks!
- chris11211
No, but it does look like there was some kind of flash fire in the tank since there is brown marks all around; brown stain on plug and the level sensor. I think I'm gonna have to replace the pump either way since it's pushing 20 now.
- 1272 Views
Last post by firstv70volvo
- 1445 Views
Last post by befarrer
- 1120 Views
Last post by 5ft24
- 3269 Views
Last post by warmblood58
- 783 Views
Last post by ifga16
