Spark Plug Tube Seal
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
pshdars
Year and Model: 2012 Volvo S60 2.5
Post by pshdars »
I recently discovered that I have oil in the spark plug tubes for my 2012 Volvo S60. I have purchased replacement seals and I am wondering what techniques people use to remove the oil from the spark plug tubes before replacing the seals and spark plugs?
dikidera
Year and Model: S60 2005
Has thanked: 67 times
Been thanked: 175 times
Post by dikidera »
I personally use thing rags and a long screwdriver. Then I push in the rags or some end of them inside and it works mostly ok.
pintomerit
Year and Model: E600
Post by pintomerit »
I insert the rags or a portion of them, and it functions fairly well.
hu5ker555
Year and Model: 2008 S60, 2015 S60
Has thanked: 42 times
Been thanked: 14 times
Post by hu5ker555 »
Had to do this on my '99 Lincoln Navigator a few years back. The cylinder was way out of reach and visibility. Used a gun cleaning rod with a Q tip on the end. Went through at least 100 Q tips. Ugh
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 999 times
Post by volvolugnut »
If there is liquid oil, a small tube and a hand vacuum pump can be used to pump out the oil. Most hand vacuum pump kits have a catch tank. Just another use for these very handy tools.
Vova585
Year and Model: 01v70xc,2016xc70...
Has thanked: 155 times
Been thanked: 141 times
Post by Vova585 »
Depends on how clean and fast you would like this job to be. All above suggestions are valid options. In a shop setting mechanic would most likely use compressed air method. Long thin tube attached to the trigger handle and inserted into tube. Place a good absorbing rug on top of the tube and let's the air do it thing. Quick and effective. After removing spark plug(if desired) one can use rug on screwdriver to quickly wipe remaining oil on the walls of the tube and it would be it. If you paid by the book telling you how long this or that job should be taking-you would try to optimize where possible.
