I have been attempting to replace my alternator. The stopping point is removing the intake manifold, which has five wires running into it for sensors. Without being quite sure how I did it, I have disconnected two wire(s) at their connectors. The remining three simply will not budge.
I understand there is a tab which must be depressed in order to separate the connector. I have tried that to the extent my fingers will permit, without luck. If I try squeezing it here and there with small pliers, am I likely to do any harm?
Electrical Connectors disconnect '08 XC70
- Krons
- Has thanked: 198 times
- Been thanked: 215 times
I tend to go with a flat screwdriver to press/pull tabs on connectors. A pick if it is a really small connector where a screwdriver won’t work.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
Faust
- Year and Model: xc70 2008
- Has thanked: 31 times
- Been thanked: 10 times
I would appreciate being pointed to a video, or even a still photo which would show the locking system on these connectors. I figured this for a four hour driveway job; this is the end of my second day, and I haven't even got the intake manifold off. I just succeeded in getting connector 4 off with the aid of a pair of tubing pliers, a tool I had forgotten I owned. Now I am down to the bottom connector which has to be reached from below, I am dreading that. All of the intake manifold videos I have seen simply say remove the electrical connectors, as though it was nothing. This not my first auto repair job.
2004 V70
1964 Plymouth Convert (small block)
1967 Dodge Coronet (big block)
Faust
I am still hoping for a hint of any sort here. I am down to the bottom connector (all instructions say most easily reached from the bottom; I have been reaching down there for 1/2 an hour); I have just spent an hour with every type of puller and squeezer I own hoping for a Eureka moment. These connectors have previously discouraged me from working on my Volvos.
2004 V70
Faust try this. Press the connector together tighter, while you compress the latch. I find the latch is often under tension from the seals
- 1924 Views
Last post by Goldchemist
- 1844 Views
Last post by mrbrian200
- 10344 Views
Last post by jonesg
- 688 Views
- 2613 Views
Last post by MadeInJapan
