2011 S40 key fob doesn't work, how to get inside and drive?
lext
Year and Model: 1994 854
Has thanked: 1 time
Post by lext »
OK so my daughter lost the main key fob for our 2011 S40. We have another key, but: 1/ it doesn't have the mechanical part, and 2/ the electronic key fob doesn't open the door (I already tried to change the battery).
Without the mechanical key, we cannot open the door to drive it anywhere (the part where the key insert into the steering wheel key hole is all plastic, so I assume it's not electronic. So although the fob doesn't open the door, I assume it will still start the car? Right?)
I called the dealer but they said the car has to be physically there for them to troubleshoot the key. If we can't drive, the only solution is tow it all the way from our driveway to the dealer, 50 miles away.
Is there any other option?
Is there a way we can get inside the door using some form of clothes hanger or lockpicking? I don't remember clearly how it looked, but my impression of the little mechanical door key was that didn't look that complicated.
94 850 non-turbo
2011 S40 T5
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
Air Wedge work well to start a gap 3:45 in the video. I've used the string method with a plastic wedge to just help the string slide easier. As for the Key Fob our P1 08 C30 came with 3 and only 1 can electronically open the door locks but they all 3 start the car.
MoVolvos
Post by MoVolvos »
2012 XC90
2012 XC90 Lock Out 3.jpg (124.08 KiB) Viewed 961 times
2012 XC90 Lock Out 1.jpg (90.68 KiB) Viewed 961 times
2012 XC90 Lock Out 2.jpg (88.75 KiB) Viewed 961 times
lext
Has thanked: 1 time
Post by lext »
Thanks, MoVolvo for the suggestion. I wasn't skilled enough to try those :) However I found out you can purchase the mechanical key by going to the dealer, giving them the VIN and showing the car title (to prove you're the owner). The cost was $160 with a 1 week wait. It's a far cry from what someone said here a few years ago ($25). But it could also be due to California inflation.
Once we have the little key then we could get in, and yes the plastic key fob works fine for the purpose of driving.
Fixing up the electronic was another matter though. If we want a new key fob + programming, it will be a bit more than $1000. If we just want to troubleshoot and fix the existing key fob, it will be ~ $650 (but there's a risk it cannot be fixed, in that case it's $1K). We would like our daughter to appreciate the (financial) consequences of absent-mindedness so we didn't pay for any of those.
Luckily for her, and us, a few days later she found the original, functional, key fob :)
94 850 non-turbo
2011 S40 T5
