Turbo Code Help 2007 XC70 - 126C: boost pressure sensor-signal too high
TempXCGuy
Year and Model: 2007 XC70
Has thanked: 1 time
Post by TempXCGuy »
Hi, I have a couple of codes and a drivability issue related to the turbo. The car is a 2007 XC70 and the two codes are:
601C: Turbocharger (TC) control system boost pressure fault - Signal too high
I have already replaced both the TCV and the MAP sensor, both were bad or highly questionable. But, I’m still getting these two codes. I am in the process of checking for boost leaks, just waiting for the smoke machine (I’m don’t think I have a leak, but I’m going to check anyway). Any other thoughts or things I could check?
Thanks in advance!
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
waste gate actuation.
can you read the boost and vac ?
Vova585
Year and Model: 01v70xc,2016xc70...
Has thanked: 228 times
Been thanked: 238 times
Post by Vova585 »
At this point I would start with replacing/inspecting vacuum lines going to the waste gate actuator and TCV. IpD is selling great silicone hoses for this(i believe it was $20). If no leaks in the hoses, I would move to check if waste gate actuator is still working(hand held vaccum brake bleeder might be of help). Might want to remove waste gate connector and inspect if it moves freely. If you are already there you already inspected short upper turbo hose that goes to the Intercooler for cracks. If that all checked good...I would try to look for an oem wiring diagram and focus on MAP. I think it is a 3 wire sensor. Dont quote me, but i think it should be on 5v reference(1 wire), constant ground(usually 3rd) and sensor/feedback wire (2nd wire). At times you might get short to power or short to ground with those aging wires. Interesting if it is a hard fault vs occurring after several drive cycles. Great idea to smoke test everything. Good luck
Has thanked: 1609 times
Been thanked: 4064 times
What reader are using? Make sure the codes map to the correct Volvo code in Vida
TempXCGuy
Has thanked: 1 time
Post by TempXCGuy »
jonesg wrote: 10 Aug 2025, 21:52 waste gate actuation.
I haven’t seen the waste gate actuate, but I can make it move with compressed air. I am seeing readings from my scanner while test driving, yes.
How do I test vacuum on these cars or what’s the best way?
TempXCGuy
Has thanked: 1 time
Post by TempXCGuy »
Vova585 wrote: 10 Aug 2025, 22:00 At this point I would start with replacing/inspecting vacuum lines going to the waste gate actuator and TCV. IpD is selling great silicone hoses for this(i believe it was $20). If no leaks in the hoses, I would move to check if waste gate actuator is still working(hand held vaccum brake bleeder might be of help). Might want to remove waste gate connector and inspect if it moves freely. If you are already there you already inspected short upper turbo hose that goes to the Intercooler for cracks. If that all checked good...I would try to look for an oem wiring diagram and focus on MAP. I think it is a 3 wire sensor. Dont quote me, but i think it should be on 5v reference(1 wire), constant ground(usually 3rd) and sensor/feedback wire (2nd wire). At times you might get short to power or short to ground with those aging wires. Interesting if it is a hard fault vs occurring after several drive cycles. Great idea to smoke test everything. Good luck
Thank you for the information. I haven’t checked the hoses between the TCV and turbo and waste gate, but I will. Major noob question here (I’m just not that familiar with turbo cars), the line going to the waste gate provides pressure and not vacuum, correct?
I’ll check wires at the MAP. I have “mapped” the output on the MAP sensor on my scanner (Autel) and it is fairly consistent until I’m accelerating. Then it spikes and drops quickly, usually results in a code shortly there after and dump of most boost produced from that point forward. I should say, it spike, then stabilizes. I will monitor voltage as well though, I’ve been watching boost.
The waste gate does move freely, but again it’s under pressure and not vacuum.
Thanks again!
TempXCGuy
Has thanked: 1 time
Post by TempXCGuy »
abscate wrote: 11 Aug 2025, 04:08 What reader are using? Make sure the codes map to the correct Volvo code in Vida
It’s an Autel MaxiCOM MK808S. Can you explain your last sentence please? Been a mechanic for a long time, but this is my first experience with a Volvo.
jonesg
Post by jonesg »
TempXCGuy wrote: 11 Aug 2025, 13:24
Thanks again!
ok , a quick test , reach in and tug lightly on the rubber coupler sleeve that connects the turbo output to the charged air pipe that goes over the engine. They can get loose and blow off under boost, dumping the boost, then get sucked back into place again when the wastegate dumps the boost, you're non the wiser until you pull on the pipe and comes off.
If thats not the problem, robert spinner has a video about volvo turbo operation.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2854 times
Been thanked: 1332 times
Post by matthew1 »
jonesg wrote: 11 Aug 2025, 17:19 They can get loose and blow off under boost, dumping the boost, then get sucked back into place again when the wastegate dumps the boost, you're non the wiser until you pull on the pipe and comes off.
That's exactly what happened to my 850 in 2008. Took an hour at a gas station at night with the hood up to figure out what was going on.
Also -> Amazon link
matthew1
Site Admin
Post by matthew1 »
TempXCGuy wrote: 11 Aug 2025, 13:26
Codes come in two varieties (that I know of)... look at this page and you'll see what I mean https://www.matthewsvolvosite.com/volvo ... wer-codes/
Also -> Amazon link
