2004 S60R ECM-91C7 Throttle Valve
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Chrisdoug307
Year and Model: 2004 s60r
Has thanked: 1 time
Post by Chrisdoug307 »
I have DTC •ECM-91C7 Throttle Valve, The pervious owner gave me 2 extra throttle bodies. One is a new ebay one and the other is a used OEM one. I installed the ebay one and it would not sweep or nothing I couldn't get it to perform the Throttle unit adaptation with the Autel scanner. So I installed the used one and with the key on I got it do the Throttle unit adaptation. I could see the value change when I did the active test. Soon as I start it will die and I have to throttle. The pervious owner told me its CEM getting to hot, he installed a computer fan and and heat sink on the chip for this reason he said. Do you think its that or do I need to get a new throttle body and wire harness?
Thank you and sorry for the long post.
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 999 times
Post by volvolugnut »
We may need some more information here.
Is this S60R new to you and you are trying to get to run? Or have you had it running/ driving and it quit?
Can you read any codes?
What is the general maintenance state of the engine? Lots of miles?
Chrisdoug307
Has thanked: 1 time
not new to me, was running and driving fine, has 150k on it. I was driving and stopped at a light and then let the clutch out and it went into limp mode. The code is ECM-91C7. i have searched and read a lot of post about it. That say to replace the throttle body and harness, just wanted to see if anyone has seen the CEM cause this before I spend money on the wrong thing
br0dy519
Year and Model: 2004 XC70
Has thanked: 123 times
Been thanked: 115 times
Post by br0dy519 »
2004 did indeed have an issue with the harness and connector. I would ohm it out and make sure you have continuity from each pin back to the ecm
04s60 2.4
04xc70 2.5t
