95 volvo 940 turbo = rough idling, hard to start
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
hello_im_alex
Post by hello_im_alex »
i recently purchased a 95 volvo 940 turbo (250 000km). it ran fine for the first 2 weeks and then it started to get hard to start in the cold mornigs (25f). Also once the car is running and i have to stop for a red light or a stop sign, the engine wll start to sputter ans sometimes stall. after which it starts right away. i brought it in to the local import mechanic. he found that the coolant temp sensor need to be replaced. he did that and then the check engine light came on and he tried to get the codes but there was a failure in the ECU. so he suggested i should get that replaced aswell. I took the car home and after a few days the same problems started to occur. Is it the ECU? Has anyone ever seen this problem before? possible solutions? any help would be greatly appreciated.
CarVolvo
Post by CarVolvo »
disconnect the MAF sensor and see if it works better for you.
THE FLEET!:
93 854 GLT 20v non-turbo 435,000 KM +
94 854 20v non-turbo 215,000 KM ..new engine
87 745 B230 non-turbo 250,000 KM (newest edition Jan '07)
86 244 GL B230 non-turbo 460,000+ KM
