I am a bit confused on the normal rotation of the exhaust VVT on 2001 V70 T5. This has the spring loaded VVT on the exhaust shaft only.
I am replacing front side cam shaft seals and have a question about the range of rotation on the VVT. I can smoothly rotate the VVT hub in the CW direction against the spring. Should there be any rotation CCW from the spring relief (no tension) position? I have no CCW rotation on my hub, but some notes seem to imply the hub should have CCW rotation from no tension position.
Spring loaded Exhaust VVT Full rotation range?
- Has thanked: 987 times
- Been thanked: 1075 times
- Has thanked: 311 times
- Been thanked: 817 times
Pretty sure the answer is "no" but without the hub in front of me I'm not fully confident answering timing questions.
This video tells you almost everything you need to know and I think answers your specific question:
Thanks! That answered many nagging concerns.
- 939 Views
Last post by Ozark Lee
- 674 Views
Last post by foggydogg
- 5163 Views
Last post by LT South Africa
- 4151 Views
Last post by jimmy57
- 1905 Views
Last post by fisker247
