daytime running lights
jim montgomery
Post by jim montgomery »
i have just purchased an 850 turbo wagon and have the opposite problem from most people who post. i have imported an american car to canada and it has no functioning daytime running lights. i hope that i can reverse one of the tricks and get them to work.
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
What year?
I believe all 850's have the DRL switch installed
In the headlight switch cluster is a separate teenie little screw head.
If the lights (DRL's) are off it should be at the 10:00 position.
You need a very tiny (eyeglasses type) screwdriver,
push the screwhead in and turn to the 12:00 position and release. You should now have DRL's
jim montgomery
the car is a 94.
i will try to locate the screw before i have to resort to any drastic measures.
thanks
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
Jim,
On my '94 the switch is actually on the back of the headlight switch so if you don't have the screw on the front of your switch pull the switch out of the dash, it just pulls out, and look on the back of the switch. The same thing applies, turn it to the middle postion.
dykaar
Post by dykaar »
I imported a 94 850 turbo wagon from the US into Canada. There is a different light switch that implements the DRL. Go to the stealership and buy it if you can't get it from fcp. It was ~$38CDN in 1996. Unplug the old one and plug in the new one. As an aside, on my 2000 BMW 540, the DRL is a software setting. Go figure.
85 535 -For sale: http://bmwclub.ca/cgi-bin/yabb2/YaBB.pl?num=1175281807
00 540
86 951 (http://www.pcaucr.org/forum/post.jsp?postid=2393)
94 855 turbo
Regards,
doug
