Timing Belt rubbing through the casing 1998 T5 C70
acfviola
Year and Model: 1998 C70
Has thanked: 2 times
Been thanked: 8 times
Post by acfviola »
Hi all, my C70’s timing belt has started rubbing through the plastic casing around it (photos attached) What could possibly cause this? I can’t even think of where to start and it has just started happening out nowhere within my most recent drive. I checked my engine bay before I left with no issues. any guidance would be greatly appreciated.
Has thanked: 2197 times
Been thanked: 1851 times
DO NOT DRIVE YOUR CAR!! The belt can break and cause engine damage.
You can remove the top section with a small 10mm socket and remove the bolt about 5-6" down on the front on the cover and slightly countersunk.
As to what is causing the belt to work its way out that far I don't know other than one of the pulleys has a failing bearing allowing the belt to move outward.
Has thanked: 1609 times
Been thanked: 4064 times
This happened to me when the timing belt tensioner failed. It wore through the plastic, jumped off the pulley, and killed the cylinder head.
Repeating…DO NOT START THE ENGINE !
cuhfs
Year and Model: 850,XC70,XC90,S60,80
Has thanked: 17 times
Been thanked: 31 times
Post by cuhfs »
Scot850 and Abscate = wise men saying "DO NOT START OR DRIVE YOUR CAR".
I hope the OP reads and heeds your advice.
I've seen that movie. :shock:
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
96 850 Wagon Manual Trans & 98 V70 (gone)
95 850 Sedan Auto Trans (gone)
04 XC70 Auto (gone)
04 C70 Convert (gone)
01 C70 Convert Manual Trans (gone)
acfviola
Post by acfviola »
Thank you for the replies all; for the record, definitely did not start my car again, would have been an absolute disaster if I did. Abscate was correct, timing belt tensioner had failed terribly, was a few mm from losing my belt completely and engine going kaput forever. In the process of replacing and changing belt now… :shock:
Nice save. You have done “ very good work”
