Volvo 850 PVC trap and hose options
JimBee
Has thanked: 33 times
Been thanked: 43 times
Post by JimBee »
I'm still running my 850s and likely to for a while. I think all 3 need better crankcase breathing.
There are a few posts suggesting workarounds for various parts—and warnings to avoid Proparts and URO.
So a couple of what-if questions:
What if you dipped a Proparts or URO pipe in some sort of hardening glue? IDK, anything that could stand the heat and beef up the plastic.
Also, what about using oil/gas resistant flexible hose like what MacMaster sells?
This search produced quite a few links—suggestions?
Search: flexible 5/8" ID hose for oil and gas
https://www.mcmaster.com/products/oil-r ... e/hose-2~/
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
There is an in-depth discussion here about alternative parts viewtopic.php?f=1&t=53448
I had good luck so far using 5/8" ID fuel/oil hose as you suggest above. I bought a short length from a vendor on eBay described as "Blue 5/8" Push Lok Fuel, Coolant, Heater Multipurpose High Temp Hose 350PSI" and it has been holding up great so far (5 years elapsed) in my PCV system.
