Hello guys, in recent time i had few issues with my ETM (magneti marelli white label), with error codes ECM-903F, ECM-91A7 and ECM-91F0. My suspect is the magnets of the motor are rubbing the windings. My question since the magnets are not repairable is will a used Volvo remanufactured unit or XeModeX work without any reprogramming. I did read somewhere that 2013 and newer Volvo replacements dont need to be reprogrammed but im not sure. Also if reprogramming is required can it be done by cloning the etm with vdash?
Any help will be appreciated!
Used ETM on '01 S60
- Been thanked: 4064 times
You need two things right for an ETM to work
Buy from Volvo or FCP, dealer programming , most expensive , no risk
Buy refurbed ftom Xmodex - ready to work, less expensive
Buy used off eBay, very reasonable, low risk if you can match year and turbo/NA ..only get the latest contactless one
Other used off eBay, about 20% chance of success - cheapest
- 16 Replies
- 3331 Views
Last post by smacknab
- 4480 Views
Last post by ajwsurfer
- 1338 Views
Last post by precopster
- 2748 Views
Last post by SuperHerman
- 4931 Views
Last post by antonevane
