2008 XC90 radiator hoses detached? from radiator? Help!
Crnivlag
Year and Model: 2008 XC90
Has thanked: 2 times
Post by Crnivlag »
My 2008 Volvo XC90 3.2 inline 6; 200k miles, in pretty good shape! Problem, surprise red light on dash saying no coolant stop engine, so I parked and investigated. Tried to refill coolant reservoir- quickly realized coolant was just running out of hose (s?) onto ground. Can see point where fluid is dumping out- seems to be a metal piece where fluid should go into radiator? Not sure what that is, will post pictures of area… any thoughts on what it is? Please and thanks in advance!!
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Likely broken rad neck, common problem in old car.
Just tow it home.
Search FCPEuro for rad review.
When in doubt, use Volvo genuine part.
Time to replace both hoses too.
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
Neck detachment is common on plastic radiators. Try to get a replacement with metal inserts inside the plastic necks. These inside rings help prevent hose clamp damage to the neck.
There are several threads about radiator replacements in MVS.
