What is this? Wire ring fell from wheel. Topic is solved
dalel
Year and Model: 1998 V70
Has thanked: 29 times
Been thanked: 7 times
Post by dalel »
What is this? I've been bangin' around alot in order to change ball joint/control arm. I took the wheel of and this wire ring fell to the ground. Measures 64.5mm. Anyone know where it came from?... Dale
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
A spring clip for a small wheel center cap? Or a ball joint seal retainer ring?
dalel
Post by dalel »
volvolugnut wrote: 10 Sep 2026, 16:54 A spring clip for a small wheel center cap? Or a ball joint seal retainer ring?
Yes! You guys are amazing. Gives tension to the wheel cap teeth. Here it is... DLL
