Hi again guys. Hope you had a great summer!
My older v70 with 228k miles on her gave me a couple of CEL's today. (P0420 & P0328)
P0420 after looking it up says it could be the CAT converter (Bank 1) or possibly a bad Mass Air Flow sensor.
Should I look into replacing the MAF sensor first? I am pretty sure the price of that CAT converter is up there.
P0328 after research, says it is the Bank 1 knock sensor causing that code. Do I need to replace that also or is it
possible that the P0420 is causing the other code to come up.
Many thanks as always for your help.
2002 Base v70 / CEL codes P0420 & P0328
Mr. Detail
- Year and Model: 2002 V70 N/A
- Has thanked: 157 times
- Been thanked: 6 times
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
P0420 refers to cat converter efficiency which is derived from information received from the downstream O2 sensor. I’ve read that the O2 sensor signal is ignored for the first couple minutes after starting a cold engine (when the engine is running super rich). An interesting experiment would be to clear the codes then start the cold engine and let it run about 30 seconds. Shut it off and scan to see if P0328 appears. If P0328 DID appear during that short engine run then I would be inclined to look into the knock sensor first.
Mr. Detail
Gentlemen, would a factory installed oxygen sensor or OEM be considered a Bosch one?
Mr. Detail
Also does the naturally aspirated 2.4L engine like mine have just 2 sensors?
Mr. Detail
chrism-
No codes after running your 30 second test just now.
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 685 times
Depends on who made the ECM. Bosch for Bosch, Denso for Denso, Siemens for Siemens. Run your car by FCP website.Mr. Detail wrote: Yesterday, 07:09 Gentlemen, would a factory installed oxygen sensor or OEM be considered a Bosch one?
vtl
Yes. Upstream sensor for close-loop air-fuel mixture, downstream sensor for CAT health monitoring. The upstream one usually goes bad first, but the downstream sensor may light up a cat efficiency error sooner than ECM understands the upstream sensor lies. Volvo's CAT is top-notch, fully metallic, hard to kill, unless owner tried hard.Mr. Detail wrote: Yesterday, 07:10 Also does the naturally aspirated 2.4L engine like mine have just 2 sensors?
The oxygen sensor related errors are registered after 3 consecutive engine starts and following detection of the sensor failure.
Mr. Detail
My original ECM went bad I think back in 2023. My local Indy Volvo mechanic replaced it with a re-manufactured Volvo ECM. That one lasted less than a year and it was under warranty, so they gave me a new re-man for no charge.
- 1654 Views
Last post by oragex
- 2449 Views
Last post by erikv11
- 922 Views
Last post by mrscullini
- 11 Replies
- 3839 Views
Last post by Bill-grim
- 17 Replies
- 4838 Views
