740 upshift
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
walt007
740 upshift
Post by walt007 »
Had an intermittent overdrive upshift problem with my '91 740. I diagnosed it as an intermittent connection in the OD solenoid using a test fixture I installed in the OD relay socket. Had Volvo dealer check it out and they verified it. However they made it perminant when tapping the solenoid with a hammer. Had the dealer replace it ( much $ ). Now it won't upshift from 2nd. (Note: When working, the shift into 3rd and overdrive appeared to occur at the same time.) Repaired and installed the old solenoid. No change. Now having a pxxxxxg contest with the dealer claiming that it came out worse than it went in. Appears to be now a valve body or governer problem.
Any ideas or suggestions? Could dirt have fallen into the solenoid ports when the new one was installed?
