Left speaker keeps shutting off, then comes back on usually when I hit the right kind of road bump LOL!. Even an occasional dashboard whack will kick it back on.
Seems like a contact problem, anyone have a fix?
Thx,
Harry
87 240 OEM radio (cl-712?)----minor problem
Harry von Zell
- Year and Model:
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
The only fix I know is to pull the radio and check the speaker connections on the back. If they are OK check the connections on the speaker. Also check for continuity of the cables in case of breakage (highly unlikely).
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
If you mean the left speaker in the door, I would definitely check where the wire passes from the body into the door. But, if you can make it work by hitting the dash, it sounds like a connection closer to the radio.
1992 240 GL
1966 Sunbeam Tiger
1966 Sunbeam Tiger
Harry von Zell
- Year and Model:
Another "CLUE" I should have mentioned......
When the left speaker "pops-off" I turn the radio off and then on again. Both speakers usually work until the left drops off again (then I do the off/on thing again...)
My guess it's a radio thing rather than a loose speaker wire....If I remember I had an 83 240, years ago, (same radio) that did this too....
Harry
Harry
Prior owner of '83 and '89 240's
wojeepster
- Year and Model:
My 240 would do that exact thing, it turned out that someone had put the door speaker in improperly and because of this the speaker would sometimes short out on the metal of the door. Removing the speaker turning it and attaching it properly solved the problem.
- 1231 Views
Last post by atomicthumbs
- 575 Views
Last post by Rabbie
